12v DC power supply output rather high?
Try this:
If your dc to dc psu gives higher than
expected voltage output...say more than 360v dc. Then it could be that your
power transistors really are turning too hard on. Increase the 470 ohm base
resistors to 680 ohm. This should result in less power being drawn from the
12v supply and deliver 350v on receive and 305v on key down. These figures
will allow the paraset to perform well and are provided for guidance. You
might get something slightly different.
