tip 1 for Valve & TT
Paraset Power Output
tip 2 for Valve
Selecting the value for C7
tip 3 for Valve & TT
Morse Keys
tip 4 for TT
Stop possible damage to the grounded gate R.F. amplifier.
tip 5 for Valve
How to feed the heaters in the Paraset
tip 6 for TT
How to make an 80m Rx coil and band spread the tuning range
tip 7 for Valve
How to make 80m Valve Paraset Rx coil and band spread the tuning range
tip 8 for valve and TT
Tuning dial friction assembly
tip 9
How long is an end fed antenna
tip 10 for valve and TT
Normal receive range but you would like some "bandspread"
tip 11 for valve
Is the P.A. working? A quick and simple test
tip 12 valve and TT
Have you got a sluggish crystal that doesn't key too well?
tip 13 for valve
12v DC power supply output rather high? Try this:
tip 14 for all sets
spraying hammerite type paint
